ProtectionOperate |
Receives an integer value from a *ProtectionOperate-type Measurement, as if it were a shortcut to the Measurement value. This property informs the current acted situation of the Protection. Possible values are 0: Normal or 1: Acted. This property makes it easy to create objects (Screen or data) that need information about Protection performance, by simply reading this property, instead of searching for a Protection's child object. This is a read-only property.
