SortMode |
This property indicates the sorting mode for Measurements, Commands, and Protections on a PowerExplorer window. Possible values for this property are -1 - smNoSort: No sorting, that is, objects are displayed in the order they are returned by the server, 0 - smAlphabetic: Alphabetical sorting (default), or 1 - smTypeSorting: Object sorting is performed based on the values informed on the Sorting column, available on Analog, Discrete, Commands, and Protections tabs of a Power Configuration object.
