GetScreenTabFrame |
GetScreenTabFrame(TabName)
When a tab containing a Screen or Frame is created on PowerExplorer, using the InsertScreenTab method, a Frame is created to contain that Screen, similar to what happens on an Elipse Power Viewer.
This method returns the tab's Frame indicated by the TabName parameter, or returns a script error if this tab does not exist or it does not have a Frame, which is the case for default tabs.
This Frame is only effectively created during the first activation of a tab. Therefore, if the tab is created but never activated, this method returns a script error.
Sub
' script to change a tab's Screen of PowerExplorer
Set PEFrame = PE.GetScreenTabFrame("ChartTab")
PEFrame.OpenScreen("ChartScreen2", 0)
With the Frame object, users can use some methods as if they were executed on an Elipse Power Viewer. For example, users can use the OpenScreen method to open a new Screen on the Frame, that is, on the tab. The following methods of the Frame object cannot be used because they cause a script error:
