OnCommandEx |
OnCommandEx(CommandInfo)
This event is triggered whenever any Command is executed, just like the OnCommand event. The CommandInfo parameter is a PowerCommandInfo-type object that contains all properties described on the next table, which are all Read-Only.
Properties of the PowerCommandInfo object
Description |
Name of the user sending this Command. It can be Elipse Power Viewer's user logon, "Anonymous" if there is no logged in user, or "System" if this method's call started at the server |
An integer that indicates the type of Command sent. Possible values for this property are 1: Operate, 2: Select, or 3: Cancel |
Command Unit object receiving this command |
Indicates the return value configured in the Template, referring to the command operation sent. Possible values for this property are Operate, Select, or Cancel |
Indicates the writing value referring to the command operation sent. Possible values for htis property are Operate, Select, or Cancel |
