<< Click to Display Table of Contents >> Locked |
This property enables or disables object's edition. If this property is set to True, edition is not allowed. Otherwise, users are allowed to edit this object. Values configured for the Enabled property influence this property's behavior. For more details, please check the Enabled property. Default value of this property is False.
