<< Click to Display Table of Contents >> CurX |
This property specifies the current horizontal position of an object's insertion point. This property is applied to an object with several rows, that is, whenever the Multiline property is enabled. The return value is valid when this object receives focus. Users can use either the Multiline property or this property to place a text's insertion point, as users use the scroll bar through object's content. When users move the insertion point to another row on a text by scrolling object's content, the CurTargetX property specifies the best position for this text's insertion point. This property is defined with this value if text row is greater than the value of CurTargetX. Otherwise, this property is defined at the end of the text row. This property cannot be changed while this object is active.
