RemoveItem |
RemoveItem(pvargIndex)
Removes items from a Combo. This method has the pvargIndex parameter, which specifies a row to remove, starting at 0 (zero). That is, the first element is 0 (zero), the second element is 1 (one), and so on. The next script contains an example of using this method.
Sub CommandButton2_Click()
ComboBox1.SetFocus
' Check if the list contains selected data
If ComboBox1.ListCount >= 1 Then
' If there is no selection,
' selects the last item.
If ComboBox1.ListIndex = -1 Then
ComboBox1.ListIndex = ComboBox1.ListCount – 1
End If
ComboBox1.RemoveItem(ComboBox1.ListIndex)
End If
