Field |
This property determines the name of a Historic Field on the database table. Default value of this property is an empty String, that is, uses the value of the Name property as the name of this Field on the database table. If this property contains a value different from an empty String, that value is used as the name of this Historic Field on the database table.
NOTE |
For applications created in versions earlier than version 5.0 and opened in version 5.0 or later in which the Name property contains a value that cannot be used as the name of an object in Elipse Power, the expression "Field_" is concatenated to the value of the Name property and used as a name for this Historic Field on the database table. |
