Context |
Context(ContextName)
Returns an object implementing the context indicated by the ContextName parameter, which must be a String surrounded by quotation marks. This method fails if no object on the upper hierarchy of the object calling this method implements that context. The following contexts are available:
•Container: Server and Viewer objects, that is, objects inserted in project files or on folders inside projects
•Area: Alarm Areas, or any server object whose IsAlarmArea property is set to True
•Device: Bay, Branch, Breaker, Busbar, Capacitor, Direct Current Branch, Distribution Load, Distribution Transformer, Feeder, Generator, Inverter, Junction Box, Line Segment, Photovoltaic Array, Photovoltaic Power Plant, Reactor, Recloser, Switch, Switch Fuse, Substation, Three-Winding Transformer, Transmission Line, Two-Winding Transformer, Voltage Regulator, Wind Power Plant, and Wind Turbine objects
•Group: Group of Commands, Group of Interlocks, Group of Measurements, Group of Photovoltaic Strings, Group of Protections, and Terminal objects
•SwitchGear: Breaker, Recloser, Switch, and Switch Fuse objects
•Transformer: Distribution Transformer, Three-Winding Transformer, Two-Winding Transformer, and Wind Turbine Transformer objects
In addition, the following specific contexts are available:
•Bay: Bay object
•Blade: Wind Turbine's Blade object
•Branch: Branch and Direct Current Branch object
•Breaker: Breaker object
•BusBar: BusBar object
•Capacitor: Capacitor object
•Commands: Group of Commands object
•Converter: Wind Turbine's Converter object
•DistributionLoad: Distribution Load object
•Feeder: Feeder object
•Generator: Generator object
•GeneratorRotor: Wind Turbine's Generator Rotor object
•GeneratorStator: Wind Turbine's Generator Stator object
•GeneratorTerminal: Wind Turbine's Generator Terminal object
•GridTerminal: Wind Turbine's Grid Terminal object
•Hub: Wind Turbine's Hub object
•Interlocks: Group of Interlocks object
•Inverter: Inverter object
•JunctionBox: Junction Box object
•LineSegment: Transmission Line Segment object
•Load: Load object
•Measurements: Group of Measurements object
•Meteorological: Wind Turbine's Meteorological object
•Nacelle: Wind Turbine's Nacelle object
•PhotovoltaicArray: Photovoltaic Array object
•PhotovoltaicPowerPlant: Photovoltaic Power Plant object
•Protections: Group of Protections object
•Reactor: Reactor object
•Recloser: Recloser object
•Rotor: Wind Turbine's Rotor object
•String: Photovoltaic String object
•Strings: Photovoltaic String Group object
•Substation: Substation object
•Switch: Switch object
•SwitchFuse: Switch Fuse object
•Tower: Wind Turbine's Tower object
•Transmission: Wind Turbine's Transmission object
•TransmissionLine: Transmission Line object
•VoltageReg: Voltage Regulator object
•WindPowerPlant: Wind Power Plant object
•WindTurbine: Wind Turbine object
•Yawing: Wind Turbine's Yawing object
NOTE |
Context names are case-insensitive. To check the context to which an object belongs, open its Properties Window, select the Item tab, and then check its valid contexts in the Contexts frame. In case an object defines more than one context, their names are presented in alphabetical order, separated by commas. |
