GetADORecordSet |
GetADORecordSet()
This method returns an ADO-type (ActiveX Data Object) Recordset as the result of executing the configured Query. The next script contains an example of using this method.
Sub Button1_Click()
Set rec = Screen.Item("Query1").GetADORecordset()
strDates = " "
i = 0
' Displays a message with the first 10 records
' of the E3TimeStamp column
While (NOT rec.EOF AND i < 10)
strDates = strDates & CStr(rec("E3TimeStamp")) & _
Chr(10) & Chr(13)
i = i + 1
rec.MoveNext()
Wend
MsgBox strDates
NOTE |
For more information about the ADORecordset object returned by this method, please check Microsoft documentation at http://msdn.microsoft.com/en-us/library/ms675841(VS.85).aspx. |
