MsgBoxEx |
MsgBoxEx(prompt, [buttons], [title], [PosX], [PosY])
This method allows displaying a default Windows dialog box and specify its position on the screen. The available parameters in this method are the following:
•prompt: Text to display on the dialog box. The maximum size of this text is approximately 1024 characters, depending on the width of the characters used. To insert line breaks on this text, separate these lines using VBScript's Chr function with values 10 (linefeed), 13 (carriage return), or a combination of these values between each line
•buttons: An optional numerical expression that represents the sum of values specifying the number and type of buttons displayed, style, default button, and whether this dialog box is modal or not. The default value of this parameter is 0 (zero), that is, only displays the OK button. Please check the next table for more information about this parameter
•title: An optional text displayed on the title bar of this dialog box. If this parameter is omitted, this dialog box does not show any title
•PosX: Indicates the position, in pixels, of this dialog box relative to the window's left margin. If this parameter is omitted, the respective dialog box's coordinate is centered on the window
•PosY: Indicates the position, in pixels, of this dialog box relative to the window's top margin. If this parameter is omitted, the respective dialog box's coordinate is centered on the window
NOTE |
If the values indicated in the PosX and PosY parameters place this dialog box outside the visible area, those values are automatically adjusted to ensure this dialog box is visible. |
Possible values for the buttons parameter are described on the next tables.
Possible values for types of buttons
Description |
Constant in VBScript |
0 |
Displays only the OK button |
vbOKOnly |
1 |
Displays the OK and Cancel buttons |
vbOKCancel |
2 |
Displays the Abort, Retry, and Ignore buttons |
vbAbortRetryIgnore |
3 |
Displays the Yes, No, and Cancel buttons |
vbYesNoCancel |
4 |
Displays the Yes and No buttons |
vbYesNo |
5 |
Displays the Retry and Cancel buttons |
vbRetryCancel |
Possible values for icon styles
Description |
16 |
Displays an icon indicating a critical message |
vbCritical |
32 |
Displays an icon indicating a question |
vbQuestion |
48 |
Displays an icon indicating a statement |
vbExclamation |
64 |
Displays an icon indicating an information |
vbInformation |
Possible values for default buttons
Description |
0 |
Indicates that the first button is the default return |
vbDefaultButton1 |
256 |
Indicates that the second button is the default return |
vbDefaultButton2 |
512 |
Indicates that the third button is the default return |
vbDefaultButton3 |
768 |
Indicates that the fourth button is the default return |
vbDefaultButton4 |
Possible values for types of modal windows
Description |
0 |
Indicates that users must respond this dialog box before continuing work on the application |
vbApplicationModal |
4096 |
Indicates that all applications are suspended until users respond this dialog box |
vbSystemModal |
This method returns a number representing the button clicked on the dialog box, according to the next table.
Return values of the MsgBoxEx method
Button |
1 |
OK |
vbOK |
2 |
Cancel |
vbCancel |
3 |
Abort |
vbAbort |
4 |
Retry |
vbRetry |
5 |
Ignore |
vbIgnore |
6 |
Yes |
vbYes |
7 |
No |
vbNo |
