OverrideFillMode |
This property specifies a fill mode for this object's picture, when displaying a Windows Metafile. It changes the picture's original fill mode without changing the file defined in the Filename property. The next table contains valid values for this property.
Available options for the OverrideFillMode property
Option |
Description |
0 - NoOverride |
Picture keeps its original fill (default) |
1 - Wideframe |
Picture is not filled |
2 - SolidFill |
Picture is filled with the color specified by the OverrideFillColor property |
3 - ByBrightness |
Picture is filled with the color specified by the OverrideFillColor property, but considers the intensity of picture's original color |
The next script contains an example of using this property.
Sub DrawPicture1_Click()
' When clicking this object sets the
' Override mode to solid
' and changes picture's fill
' color to blue
OverrideFillMode = 2
OverrideFillColor = RGB(0, 0, 255)
NOTE |
This property is only effective when a Picture object is working with Metafiles (WMF or EMF). |
