EnableOverrideLineColor |
This property enables or disables a Group object to override original colors of lines on objects contained in that Group. If this property is enabled, original colors of lines on objects in that Group are replaced by the color defined in the OverrideLineColor property. Otherwise, each object contained in that Group displays its original line color. Default value of this property is False.
