Picture |
This property specifies an image (bitmap) attributed to an object. An image file can be selected via Properties List or via scripts, by using the LoadPicture function to specify a file path and name containing an image. To remove an image, click the value of this property and press the DEL key. The BACKSPACE key does not remove an image.
