CaptionPosition |
Specifies the position of the text in the Caption property of a Barcode object. The available options for this property are 0 - ddbcCaptionNone: Text of the Caption property does not appear in the Barcode (default), 1 - ddbcCaptionAbove: Text of the Caption property appears above the Barcode, or 2 - ddbcCaptionBelow: Text of the Caption property appears below the Barcode.
