OnValue |
This property specifies the value a property assumes when source's expression returns True. The next script contains an example of using this property.
Sub OnValue_Click()
On Error Resume Next
Dim Value
If Application.ShowPickColor_
(Value, ForegroundColor, 400, 300) Then
Dim Bind
Set Bind = Screen.Item("Rectangle1").Links._
Item("ForegroundColor")
If Bind Is Nothing Then
MsgBox "Rectangle1 has no link."
Else
MsgBox "Rectangle1 is linked to "& Bind.Source & " "
MsgBox "Changing OnValue from " &_
Bind.OnValue & " to " & Value
Bind.OnValue = Value
End If
ForegroundColor = Value
End If
