Format |
This property specifies the type of format applied to this object. It allows changing the way data is displayed without changing data behind it. This property can be manually edited or configured using the formatting window. Its usage is similar to formats used on spreadsheets, following the same basic syntax. Data types described on the next table are supported.
Data types supported by the Format property
DATA |
DESCRIPTION |
Number |
Decimal, scientific, hexadecimal, binary, and octal output |
Text |
General text |
Boolean |
Boolean values |
Date and Time |
Gregorian calendar |
