BeforeDropOrPaste |
BeforeDropOrPaste(Index, Cancel, Ctrl, Action, Data, X, Y, Effect, Shift)
Triggered immediately before a drag-and-drop operation. Usually, this occurs right after a BeforeDragOver event.
Available parameters on the BeforeDropOrPaste event
Name |
Description |
Index |
Indicates a page index, in a multi-page object, that is affected by the operation that generated this event. For other objects it is ignored |
Cancel |
Event status. Default is False and indicates that the target object handles this event and not the main application |
Ctrl |
Target object |
Action |
Indicates the result, based on keyboard settings, of a pending drag-and-drop operation. Possible values are 2 - fmActionPaste: Pastes the selected object on the target object or 3 - fmActionDragDrop: Indicates that users dragged the selected object from its origin and dropped it on the target object |
Data |
Data being dragged to the target object |
X, Y |
Position of the mouse pointer inside the target object, in points. X is measured from object's left side and Y is measured from object's top |
Effect |
Indicates all actions the target object supports, that is, the effect of dragging over that object. Possible values are 0 - fmDropEffectNone: The target object does not accept copying or moving from any origin, 1 - fmDropEffectCopy: The target object allows copying from any origin to it, 2 - fmDropEffectMove: The target object allows moving from any origin to it, or 3 - fmDropEffectCopyOrMove: The target object allows copying or moving from any origin to it |
Shift |
An integer whose sum of factors indicates the status of SHIFT, CTRL, and ALT keys. Possible values are 1: SHIFT key pressed, 2: CTRL key pressed, or 4: ALT key pressed. For example, a value equal to 5 (five) indicates that SHIFT and ALT keys were pressed (1 + 4 = 5) |
