Properties |
This section contains information about the properties of an E3Alarm object.
NOTE |
Elipse Power uses, when defining coordinates and widths, the Himetric system. In this system, each logical unit is equivalent to one hundredth of a centimeter, that is, every 1000 units are equivalent to one centimeter. Thus, this is the standard adopted when describing Elipse Power properties, when applicable. |
The available properties on this section are the following:
•Font
