OnOperate |
OnOperate(ActorID, WriteValue, FeedbackValue, Failed)
Defines which task is executed when the Operate method, available on an instance of the Command Unit object, is called. The most basic task performed by this script is writing the value of the Operate Value field (configured in the Command Action area) to the OperateWriteTag property (configured in the Command object) and setting the value of the Failed parameter.
Description of parameters
Name |
Description |
ActorID |
Informs to a script the name of the user passed to the Operate method in the Command Unit. If omitted when calling that method, assumes Elipse Power Viewer's user logon, "Anonymous" if there is no user logged on, or "System" if this method's call started at the server |
WriteValue |
Informs all values configured in the creation area of Command Actions for this event, according to the action type, such as "Open" or "Close". This parameter has the value of the Operate Value field |
FeedbackValue |
This parameter contains all values configured in the creation area of the Command Actions for this event. This parameter initially has the value of the Operate FeedBack field. If needed, a script may change this value, and at the end of that script the modified value is the expected returned value. This allows evaluating incremental-type commands |
Failed |
A Boolean used to indicate a failure detection in the Command Action scripts. This value must be set to False if that action succeeds, as it starts that script with its value as True |
