Rounded Rectangle
Rounded Rectangle
A Rounded Rectangle object is a rectangle created from two vertexes, with rounded corners based on a rounding factor. When inserted or edited, it displays a small dot next to its upper left corner, which allows modifying its rounding factor.
Rounded Rectangle
Rounded Rectangle
After inserted on a Report, this object is named as "Shape".
