Other Implementations
Fixed a problem when generating dump (.dmp) files when two or more simultaneous exceptions occurred in different threads. This bug occurred since v6.0.73.
The interface to edit Event Recordings now validates and instructs about the usage of macros. This bug occurred since v3.0.456.
Changed the notification of E3 Server clients to support reentrant calls.
Fixed the name of the Windows Registry Key from where the configuration of logs ProcessInfo.<process>, HeapLog.<process>, and Profile.<process> is read. Now, there is no need to add an x64 suffix to 64-bit processes. This bug occurred since v4.6.114.
