<< Click to Display Table of Contents >> Documentation |
•Removed information about compatibility with E3Chart on Query's AddField and RemoveField methods and removed a text indicating that Query's DataSource, Fields, GroupBy, Having, OrderBy, Table, and Where properties were read-only but could be changed at run time on Elipse Power Reference and Scripts Manual. This bug occurred since v1.20.1.
•Fixed the names of Electrical Studies in ActiveSource and StudyInputSource properties of Analog and Discrete Measurements on Elipse Power Reference and Scripts Manual. This bug occurred since v3.5.245.
•Added a link to the SortMode property on the initial topic of PowerExplorer properties on Elipse Power Reference and Scripts Manual. This bug occurred since v4.7.169.
•Fixed the description of Screen's FillStyle property, which is also common to Screen objects on Elipse Power Reference and Scripts Manual. This bug occurred since v4.7.115.
•Updated the descriptions of BackupDiscardInterval, BackupDiscardTimeUnit, DiscardInterval, DiscardTimeUnit, EnableBackupTable, EnableDiscard, VerificationInterval, and VerificationUnit properties, which are common to Alarm Server, Self-Healing Electrical Study, Historic, and Storage objects, so that they indicate to which object they refer on Elipse Power Reference and Scripts Manual. This bug occurred since v3.0.365.
•Updated the exercise about expressions on chapter Links of Elipse E3 Tutorial Developer. This bug occurred since v4.5.250.
•Fixed the figure of Properties List that appears on chapter Starting the Application of Elipse E3 Tutorial Developer. This bug occurred since v4.7.292.
•Fixed a situation where some topics that should not be included on Elipse Power documentation in CHM were improperly added. This bug occurred since v4.5.99.
•Reintroduced a paragraph about context variables that was removed from Elipse Power User's Manual on topic Links. This bug occurred since v4.0.205.
•Fixed the name of the property defining the line style of a Pen, PenLineStyle, on Elipse Power User's Manual and on Elipse Power Reference and Scripts Manual. This bug occurred since v3.5.98.
•Removed the indication that the Size property cannot be changed after activating communication in I/O Block, OPC Block, and OPC UA Block objects on Elipse Power Reference and Scripts Manual. This bug occurred since v1.20.237.
•Added the value of the ClassName parameter for OPC UA Driver object in E3StudioApplication's CreateFile method on Elipse Power Reference and Scripts Manual. This bug occurred since v4.5.204.
•Fixed standard values of GradientStyle (Screen), BorderStyle (Scale), MatchEntry (List), GridLinesType (E3Browser), LineStyle (Report's Picture), and Alignment (Report's Text) properties on Elipse Power Reference and Scripts Manual.
•Fixed the example script for the GradientStyle property of Screen object Scale on Elipse Power Reference and Scripts Manual. This bug occurred since v3.2.140.
•Added the description of the Screen property of Feeder and Substation objects on Elipse Power Reference and Scripts Manual. This bug occurred since v4.6.65.
•Fixed texts on several topics of Elipse Power HMI Tutorial. This bug occurred since v4.7.301.
•Fixed the name of the Power Configuration object through all Elipse Power documentation. This bug occurred since v3.5.252.
