<< Click to Display Table of Contents >> Elipse Power Standard Libraries |
•Changed the size of a BusBar object, which nows has the same size of the device. With it, even if there is any Connector on the edge of this object, it is drawn correctly. This bug occurred since v3.5.85.
•Centered the figure of a BusBar object inside a device. This bug occurred since v3.5.85.
