<< Click to Display Table of Contents >> Database |
•Corrected a problem with the management of connections with SQL Server and Access database, which made valid Formula connections to be discarded, generating an excessive consumption of resources, and also preventing the SaveFormulaValues and SetValueData methods of the Formula object to work, and may lead to GPFs in the E3Run process. This bug occurred since v3.2.217.
•If a Database connection fails, now Elipse Power does not consume the database operation queue anymore, until connection is successful. In addition, any connection failure leads to using a reconnection policy, or waiting time. This bug occurred since v1.18.147.
•Corrected a failure in the processing of .e3i and .e3o files larger than 4 GB. This bug occurred since v2.0.35.
