TransparentColor |
When the TransparentMode property is set to 1 (one), this property defines which color on this picture is not drawn, and that picture remains transparent in these areas. In scripts, use VBScript's RGB method to create a color to link to this property. Default value of this property is white (RGB(255, 255, 255)). The next script contains an example of using this property.
Sub DrawPicture1_Click()
' Leaves the blue color transparent
' when clicking this object
TransparentMode = 1 ' ByColor
TransparentColor = RGB(0, 0, 255)
