<< Click to Display Table of Contents >> Standards for Voltage Levels |
The Voltages tab allows users to configure device colors based on their nominal voltages, that is, the BaseVoltage property. These colors are accessible at run time in Terminals' VoltageColor properties, used by the Electrical Modeler during edition, and can be also configured at run time in the object returned by the VoltageColors property of the Power Configuration object. The (Default) level color is used when a device presents a voltage not found on its color table. The tab to include voltage levels is displayed on the next figure.
Voltages tab
This tab's toolbar contains the options Add , to create a new voltage level, Delete
, to remove a voltage level, and Sort
, which sorts the visualization of the list of voltage levels. The available columns to edit voltage levels are described on the next table.
Columns to edit voltage levels
Column |
Description |
Nominal Voltage (kV) |
Value, in kV, of the registered voltage level. Corresponds to the NominalVoltage property of the Voltage Color object |
Energized color |
Color referring to the registered voltage level, when a Terminal is energized. Corresponds to the ColorEnergized property of the Voltage Color object |
Follow energized color |
When this option is selected, the de-energized color of this voltage displays a darker shade of the selected color in the Energized color option. Corresponds to the FollowEnergized property of the Voltage Color object |
De-energized color |
Color referring to the registered voltage level, when a Terminal is not energized. This field can only be configured if the Follow energized color option is not selected. Corresponds to the ColorDeEnergized property of the Voltage Color object |
