<< Click to Display Table of Contents >> Script |
Let's create a "Quit" Command Button so that users can close this application.
1.On the Menu_Screen, insert a new Command Button with its Caption property equal to "Quit".
2.On this Quit Command Button, create a new script.
Option to create a new script
3.To insert comments in a script, start a line with an apostrophe. Type the following text.
'Quit the application
4.In the next line, open AppBrowser , select Viewer's Exit method, and then click Paste.
Application.Exit
5.Execute this application and test this new functionality.
CHALLENGE IX |
Create a Command Button near the alarm banner to acknowledge all active alarms in this application. |
TIP |
This action can be performed using a method from an E3Alarm object. |
