Accessing Server Properties from the Server |
If users want to access properties of a Tag from another Tag, source and destination are on the server connected via a parent module, which is Driver1.
In this case, the Parent property must be used. This allows first accessing the parent object where the script is, and then users traverse the hierarchy to look for another element, according to the next figure and example.
Driver1 is the parent object of Tag1 and Tag2
Sub Tag1_OnRead()
Parent.Item("Tag2").AllowRead = False
If users are inside a group and they want to access the same Tag2, they can nest several Parent commands, according to the next figure and example.
Folder1 is the parent object of Tag1
Sub Tag1_OnRead()
Parent.Parent.Item("Tag2").AllowRead = False
