WriteValueMode |
Read-and-write property controlling the behavior of sending a value on writing operations. This property must be configured according to the OPC UA server used, or this writing fails. Possible values for this property are 0 - wvmDefault: Follows the default behavior, that is, the behavior configured in the OPC UA Driver to which this OPC UA Tag belongs, 1 - wvmValueOnly: Writes only the value, or 2 - wvmValueQualityTimestamp: Always sends the quality and time stamp with the value.
