WriteFeedbackMode
WriteFeedbackMode
Enum This property allows controlling a confirmation or feedback of Tag writings. The configuration options for this property are described on the next table.
Available options for the WriteFeedbackMode property
Option
Description
0 - wfWaitNextRead
After writing, waits normally for the next reading
1 - wfImmediateReadAfterWrite
Forces an asynchronous reading of a device right after each writing (default)
2 - wfTrustWriteSuccess
The written value is immediately assumed by the Tag, if the writing was successful
NOTES
This property cannot be changed with the object still active.
In option 2 - wfTrustWriteSuccess, for asynchronous writings, the value is assumed in the Tag after scheduling a writing, if the operation is successful. However, if that writing fails later, the Tag's value may be wrong. For synchronous writings, the value is assumed right after the writing finishes, if successful.
