OperateScript |
Text with the code for the OnOperate event. A minimum script for this event can be created by using the AddOperateScript. The String configured in this property (equivalent of using the AddOperateScript method with its Reset parameter in True) must be in the format required by this event. The default script for the OnOperate event is the following:
Sub OnOperate(ActorID, WriteValue, FeedbackValue, Failed)
Set Tag = Application.GetObject(OperateWriteTag)
Failed = Not Tag.WriteEx(WriteValue)
NOTES |
•Configuring an event's non-standard String to this property generates a script error, except when configuring an empty String. •If this String contains the new line (Chr(10) or vbLf) or carriage return (Chr(13) or vbCr) characters isolated, these characters are replaced by the combination of them (Chr(13) + Chr(10) or vbCrLf). |
