DeleteItem |
DeleteItem(Id)
Deletes the element indicated by the Id parameter of the Electrical Model.
NOTES |
•The element indicated by the Id parameter is deleted together with all its references and connections. •For more information about the format of the Id parameter, please check the ID property, common to all devices. |
