<< Click to Display Table of Contents >> EuHigh |
This property returns or configures the maximum value of the engineering unit of an Analog Measurement. The initial value of this property is inherited from the Analog Measurement Type's EuHigh property. If the selected Analog Measurement Type does not exist, this property's value is zeroed. Default value of this property is 100.
