PicturePosition |
This property specifies the position of a picture set to an object relative to its legend. Available options for this property are described on the next table.
Available options for the PicturePosition property
Option |
Description |
0 - fmPicturePositionLeftTop |
Picture appears on legend's left side. This legend is aligned to picture's upper side |
1 - fmPicturePositionLeftCenter |
Picture appears on legend's left side. This legend is centered relative to the picture |
2 - fmPicturePositionLeftBottom |
Picture appears on legend's left side. This legend is aligned to picture's lower side |
3 - fmPicturePositionRightTop |
Picture appears on legend's right side. This legend is aligned to picture's upper side |
4 - fmPicturePositionRightCenter |
Picture appears on legend's right side. This legend is centered relative to the picture |
5 - fmPicturePositionRightBottom |
Picture appears on legend's right side. This legend is aligned to picture's lower side |
6 - fmPicturePositionAboveLeft |
Picture appears above the legend. This legend is aligned to picture's left side |
7 - fmPicturePositionAboveCenter |
Picture appears above the legend. This legend is centered below the picture (default) |
8 - fmPicturePositionAboveRight |
Picture appears above the legend. This legend is aligned to picture's right side |
9 - fmPicturePositionBelowLeft |
Picture appears below the legend. This legend is aligned to picture's left side |
10 - fmPicturePositionBelowCenter |
Picture appears below the legend. This legend is centered above the picture |
11 - fmPicturePositionBelowRight |
Picture appears below the legend. This legend is aligned to picture's right side |
12 - fmPicturePositionCenter |
Picture appears at the center of the control. The legend is centered horizontally and vertically on top of the picture |
