AddSubCondition |
AddSubCondition([Name], [Caption], [Message], [Kind], [AckRequired], [Severity], [Value])
Adds a Subcondition object to the collection of Subconditions. This method has the optional parameters described on the next table.
Parameters of the AddSubCondition method
Parameter |
Description |
Name |
Object's name. Corresponds to Subcondition's Name property. If omitted, the Subcondition is then created as "Subcondition". If the value passed on this parameter already exists in the collection, it is automatically incremented. Please check the general Name property for more information about the allowed characters on the names of objects |
Caption |
Object's description. Corresponds to Subcondition's Caption property. If omitted, Subcondition's description is an empty String |
Message |
Subcondition's message text. Corresponds to Subcondition's Message property. If omitted, Subcondition's message is an empty String |
Kind |
The type of behavior of this Subcondition. Possible values for this parameter are 0: Alarm, 1: Event, or 2: Return. Corresponds to Subcondition's Kind property. If omitted, Subcondition's behavior is 0 (zero, Alarm) |
AckRequired |
Indicates whether this Subcondition requires acknowledgment. Corresponds to Subcondition's AckRequired property. If omitted, Subcondition requires acknowledgment |
Severity |
The type of severity of this Subcondition. Possible values for this parameter are -2: Critical, 0: High, 1: Medium, or 2: Low. Corresponds to Subcondition's Severity property. If omitted, Subcondition's severity is 1 (one, Medium) |
Parameter containing a value that is evaluated to determine whether this alarm occurs or not. Corresponds to the Value property, common to all Alarm Sources. If omitted, Subcondition's value is Null |
