HiHiEvent
HiHiEvent
Boolean Defines whether an Alarm's HiHi subcondition must be treated as an Event. If the Event property, common to all Alarm Sources, is set to True, this property cannot be modified, and its value always remains as True. This property cannot be changed while this object is active.
