OnRead |
OnRead()
Occurs when a value from an OPC UA Block Tag is received from an OPC UA server. Use this event to perform an operation right after some data is modified in an OPC UA Block Tag, in the Bit00 to Bit31, Quality, RawValue, TimeStamp, and Value properties of any OPC UA Block Element.
