OnRead |
OnRead()
This event occurs when an OPC Block's value is received from an OPC Server. Use the OnRead event when performing an operation right after modifying data in the OPC Block, in the Bit00 to Bit31, Quality, RawValue, TimeStamp, and Value properties of any OPC Block Element.
