Standards for Colors in Measurements |
The Measurements tab allows users to configure colors returned, at run time, in the MeasurementColor properties of Measurements and Measurement Sources, according to their statuses. This color table can be configured at run time in the object returned by Power Configuration's MeasurementColors property. The tab to configure colors of Measurements is displayed on the next figure.
Measurements tab
The columns available to edit Display colors are described on the next table.
Edition columns for colors of Measurement Displays
Column |
Description |
Measurement status |
Describes meter's status, which considers the following possibilities: Normal (good quality), Not acked alarm, Acked alarm, and Bad Quality. This is a read-only property |
Color |
Color displayed when a meter is in this status |
Blink? |
Indicates whether a display must blink when a meter is in this status |
Colors for Measurement statuses and their blinking information can be configured by script using the object returned by the MeasurementColors property of the Power Configuration object, according to the next tables.
Configuration options for colors of Measurement statuses
Status |
Default Color |
Description |
Normal (good quality) |
Yellow or RGB(255, 255, 0) |
Corresponds to the ColorNormal property of the Measurement Colors object |
Not acked alarm |
Red or RGB(255, 0, 0) |
Corresponds to the ColorNAck property of the Measurement Colors object |
Acked alarm |
Blue or RGB(0, 0, 255) |
Corresponds to the ColorAlarm property of the Measurement Colors object |
Bad quality |
White or RGB(255, 255, 255) |
Corresponds to the ColorBad property of the Measurement Colors object |
Blinking options for Measurement statuses
Status |
Default Blinking |
Description |
False |
Corresponds to the BlinkNormal property of the Measurement Colors object |
Not acked alarm |
True |
Corresponds to the BlinkNAck property of the Measurement Colors object |
Acked alarm |
False |
Corresponds to the BlinkAlarm property of the Measurement Colors object |
Bad quality |
False |
Corresponds to the BlinkBad property of the Measurement Colors object |
