E3 Server |
E3 Server coordinates all Elipse Power modules. It always executes as a service, even in Demo mode, whether it was registered as a service or with the /regserver parameter, and it must also always be executing. It can also be started when a local Elipse Power Studio is initialized, or using a shortcut to execute a Domain, such as e3admin -start app.dom. It is responsible for:
•Checking and managing usage of licenses for different Elipse Power modules
•Starting, stopping, or monitoring Domain's runtime process, E3Run
•Opening, editing, or manipulating DOM files
•Controlling user access to Domain objects
•Monitoring other Domain servers and implementing Hot-Standby
An E3 Server is capable of working with only one Domain file at a time, and this one is called the open Domain. Domain files can only be manipulated via E3 Server.
