System Time |
1.In Organizer, select the Server objects - Data objects - Data item.
2.Insert a Demo Tag named "Clock".
Add Demo Tag
3.Configure this Tag's Type property to 3 - CurrentTime.
4.Open the Menu_Screen window and insert a new Display on the Screen's corner, to display the current time.
5.Open the properties window of this object and select the Formatting tab. Define the format as Time and, in the Type item, select 13:06:03. This format displays hours, minutes, and seconds.
System time's format
6.Select the Links tab. In the Value property, use the AppBrowser to select, on Source column, the Demo Tag Clock (in Server objects - Data objects - Data). On the right, select the Value property and click Paste. Information goes from Tag to Display, therefore this is a Simple-type Link (Property « Source).
Link on the Display
CHALLENGE XIII |
Configure a pre-established script on Viewer to execute a user log off every day at 19:00. |
