LoginUser
LoginUser
LoginUser(Username, UserPassword, [OpStatus], [WarnDaysToExpire])
Executes a login operation for a specific user without displaying any message. The Username parameter is a user's name and the UserPassword parameter is the password for that user. The optional return parameter OpStatus is a map of bits indicating the status of that operation and the optional return parameter WarnDaysToExpire indicates the number of days until UserPassword expires. This method returns a Boolean indicating whether the operation failed or not. Please check the next tables for more information about possible values in case of failure.
NOTE
This method is only available if the logged-in user belongs to an Elipse Power Domain.
Possible return values for the OpStatus parameter
Value
Description
0x000000
No error
0x000001
Unspecified error
0x000002
Incorrect user or password
0x000004
The current password must be changed
0x000008
The current password expired
0x000010
This user's account is blocked
0x000020
This user's account is disabled
0x000040
The RPC server is not available
0x000080
Authentication mode not supported
0x001000
Password not informed
0x002000
This user has no permission to change their password
0x004000
The informed password is not alphanumerical
0x008000
The informed password does not contain upper and lower case letters
0x010000
The informed password is too short
0x020000
The informed password does not contain the minimum number of numbers
0x040000
The informed password does not contain the minimum number of letters
0x080000
The informed password does not contain the minimum number of special characters
0x100000
The informed password is equal to the user's name
0x200000
The informed password was recently used
0x400000
The current password did not reach its minimum duration
Possible return values for the WarnDaysToExpire parameter
Value
Description
-1 (minus one)
This password is outside the expiration interval or it never expires
0 (zero)
This password expires today
n
This password expires in n days inside the configured expiration interval
