Type |
Indicates the type of User Event. Possible values for this property are the following:
•0 - uetOnEvent: the User Event triggers whenever the value of the expression changes from False to True (default)
•1 - uetWhileTrue: the User Event triggers periodically while the value of the expression is equal to True
•2 - uetOnValueChanged: the User Event triggers when the value of the expression changes
