Bit00 to Bit31
Bit00 to Bit31
Boolean These properties together represent all 32 bits of the value available in the OPC UA Tag's Value property, where Bit00 is the least significant bit and Bit31 is the most significant bit. Changing each one of these bits implies in also changing Tag's Value property and vice versa, but this only happens when the UseBitFields property is set to True. Default value of these properties is False.
NOTE
Bit values, from Bit00 to Bit31 properties, are not affected by scale adjustments, that is, they represent the bits from a value read from a device before conversion.
