ActiveTab
ActiveTab
Text Returns or selects the active tab on a PowerExplorer window. If the name configured in this property is invalid, that is, an empty String or a non-existent tab name, a script error is then generated. This property is updated whenever a new tab is selected on a PowerExplorer window. Likewise, if the active tab is removed, by using the RemoveScreenTab method, this property is also updated to reflect the new active tab.
