TapTerminal |
Terminal where a tap is located on a Distribution Transformer. This is a read-only property. Possible values for this property are the following:
•0: No tap (default)
•1: Terminal 1
•2: Terminal 2
To change tap's position, users must use this object's contextual menu. This value is usually imported from the electrical model.
