StudyInputSource |
Determines the active source for the Electrical Study. Possible values for this property are the following:
•-1: None (default)
•0: Active Source
•1: SCADA
•2: Operator
•3: Control Center
•4: Billing
•5: Calculated
•6: Database
The selected source type must exist in the Measurement to be set as an Electrical Study input. If this property is set to 0 (ActiveSource), it follows the configuration performed in the ActiveSource property. It is not possible to select type 0 (ActiveSource) if the ActiveSource property is set to 100, 101, 102, 103, 104, 105, or 106 (Electrical Study outputs). In case the selected source is deleted, this property assumes a value of -1 (None).
