ServerMachine
ServerMachine
Text This property determines the address of the station where the OPC server is executing. For applications executing locally, this property may remain blank (default). Otherwise, users must specify a path, such as "\\ServerName". This property can only be modified when the OPC Driver is disconnected. Example:
Sub CommandButton1_Click()
  Set Opc = Application.GetObject("OPCDriver1")
  Opc.Deactivate
  Opc.ServerId = "ElipseSCADA.OPCSvr.1"
  Opc.ServerMachine = "\\server2"
  Opc.Activate
