Run Application |
Executes a specific application.
Settings for the Run Application Pick
Available options for Run Application Pick
Option |
Description |
Command |
By clicking , users can browse the disk to select an application file to execute |
Parameters |
Allows specifying arguments for application's call |
Start in folder |
Determines the working directory of the application to execute |
Window type |
Determines the type of the execution window for the application. Possible values are Normal, Minimized, or Maximized |
